(c)perso.wanadoo.fr
Year: 1996
Make: Vector
Model: M12
Base Price: $184 000 USD
Top Speed: 190.0 MPH / 305.8 KPH
¼ mile: 12.7 Seconds
Lat. Acceleration: 0.92 G
0 - 60 MPH: 4.8 Seconds
0 - 100 MPH: 10.0 Seconds
Gas Mileage: City: 9 MPG / Hwy: 13 MPG
Configuration: V12
Valvetrain: DOHC 4 Valves / Cyl
Displacement: 348.3 CI / 5707 CC
Power: 490.0 BHP / 365.4 KW @ 6800 RPM
Torque: 425.0 FT LBS / 576.2 NM @ 5200 RPM
Redline: 7600
Bore: 3.43 IN 87.0 MM
Stroke: 3.15 IN 80.0 MM
Drive Wheels: Mid Engine / RWD
Curb Weight: 3600 LBS 1633 KG
Length: 188.2 IN / 4780 MM
Width: 79.5 IN / 2019 MM
Height: 44.5 IN / 1130 MM
Wheelbase: 108.0 IN / 2743 MM
Steering: Rack & Pinion w/Power Assist
Materials: Carbon Reinforced Fibreglass
Front Brakes: Vented Discs w/Vacuum Assist
Front Brake Size: 12.6 IN / 310 MM
Rear Brakes: Vented Discs w/Vacuum Assist
Rear Brake Size: 12.2 IN / 310 MM
Front Wheels: 18.0 x 8.0 IN / 45.7 x 20.3 CM
Rear Wheels: 18.0 x 12.0 IN / 45.7 x 30.5 CM
Front Tires: 235/40ZR-18
Rear Tires: 325/30ZR-18
Transmission: 5-Speed Manaul
1st Gear Ratio: 2.23:1
2nd Gear Ratio: 2.23:1
3rd Gear Ratio: 1.09:1
4th Gear Ratio: 0.85:1
5th Gear Ratio: 0.66:1
Final Drive Ratio: 4.22:1
(c)maximum-cars.com
