Obecny czas: Czw, 25.04.2024, 19:51
[ 18 posty(ów) ] |
Jaguar XKR-S and Maserati GranTurismo MC
johny
2012 Jaguar XKR-S Base price: $132,875 Powertrain Engine: 32-valve DOHC supercharged V-8 Displacement: 5.0 liters (305 cu in) Power: 550 hp @ 6000 rpm Torque: 502 lb-ft @ 2500 rpm Transmission: 6-speed automatic Drive: Rear-wheel Chassis Steering: Hydraulically assisted Suspension, front: Control arms, coil springs Suspension, rear: Multilink, coil springs Brakes: Vented discs, ABS Tires: Pirelli PZero Tire size f, r: 255/35YR-20, 295/30YR-20 Measurements L x W x H: 188.7 x 74.5 x 51.6 in Wheelbase: 108.3 in Track F/R: 61.4/63.3 in Headroom F/R: 37.4/30.2 in Legroom F/R: 43.0/27.6 in Cargo capacity: 11.7 cu ft Weight: 3968 lb Performance 0-60 mph: 4.2 sec top speed: 186 mph epa mileage: 15/22 mpg -------------------------------------------------------------------------------- 2012 Maserati GranTurismo MC Base price: $143,400 Powertrain Engine: 32-valve DOHC V-8 Displacement: 4.7 liters (286 cu in) Power: 444 hp @ 7000 rpm Torque: 376 lb-ft @ 4750 rpm Transmission: 6-speed automatic Drive: Rear-wheel Chassis Steering: Hydraulically assisted Suspension, front: Control arms, coil springs Suspension, rear: Control arms, coil springs Brakes: Vented discs, ABS Tires: Pirelli PZero Tire size f, r: 245/35YR-20, 285/35YR-20 Measurements L x W x H: 194.2 x 75.4 x 52.9 in Wheelbase: 115.8 in Track F/R: 62.4/62.6 in Headroom F/R: 39.0/35.8 in Legroom F/R: 41.7/30.1 in Cargo capacity: 9.2 cu ft Weight: 4145 lb Performance 0-60 mph: 4.8 sec top speed: 185+ mph epa mileage: 11/19 mpg źródło: automobilemag
Broń Masowego Wyprzedzania
Śro, 15.02.2012, 23:59 |
Alfisti4ever
Re: Jaguar XKR-S and Maserati GranTurismo MC
Maserati bez dwóch zdań Piękna maszyna w każdym calu, każdym detalu, coś pięknego
Czw, 16.02.2012, 0:03 |
hajper
Postów: 636 Miejscowość: Konstancin [WPI]
Samochód: V8 M60B40
Tylko Maserati. Nic więcej.
_________________ HABEMUS SEDAN
Czw, 16.02.2012, 1:14 |
polac
Postów: 3319 Miejscowość: Miechów
W sumie to oba są świetne i ciężko dokonać między nimi wyboru ale widzę że są już co najmniej dwa głosy na włocha to ja zagłosuję na Jaguara co by mu smutno nie było
_________________ [']Zulu-2.X.1990-11.II.2007-PAMIĘTAMY!!!![']
Czw, 16.02.2012, 10:33 |
choopster
Postów: 2897 Miejscowość: Inowrocław | Poznań
Jaguar w wersji R-S jest obłędny, ale przy tym Maserati startu nie ma. sorry memory.
Czw, 16.02.2012, 11:26 |
johny
Jaguar w tej specyfikacji wyglada niesamowicie, wszystko mi się w nim podoba, do tego ma więcej mocy niż rywal. Maserati też jest super ale mnie jakoś specjalnie nie kręci
Czw, 16.02.2012, 13:54 |
morphy
Postów: 3978 Miejscowość: Pomorze
Mogę wziąć oba?
Jaguar i Maserati. Gdy będę miał duży garaż i kilka kont bankowych na pewno dla nich znajdzie się miejsce. Oba szybkie, oba głośne, oba dostarczające podwójną dawkę adrenaliny i emocji i do tego oba piękne. Jakbym musiał wybrać tylko jednego z nich to wziąłbym Jaguara, ale tylko dlatego, że jest....tańszy. Innego wyznacznika nie mogę znaleźć.
Czw, 16.02.2012, 14:07 |
zygix
Postów: 929
Samochód: Viggen
Bez chwili zastanowienia Maserati
_________________ ,,Lepiej milczeć i sprawiać wrażenie głupca, niż przemówić i rozwiać wszelkie wątpliwości'' - Lincoln
Czw, 16.02.2012, 14:54 |
bartez
Oba świetne i ciężko się zdecydować. W Maserati jedyne co mi się nie podoba to kolor skóry; czerwony jest zbyt oczojebny dlatego głos na brytola.(lub hindusa jak kto woli )
Czw, 16.02.2012, 17:06 |
Michae
No no, pierwszy raz widzę Twojego posta zygix bez jakiejś oryginalnej emotki ;p W Maserati świetne jest wnętrze w burdel-style Co prawda tył i przód w tym aucie nie wyszły najlepiej, ale w tym przypadku to jedyny słuszny wybór przy przestarzałym Jagu
_________________ Czas dostrzec, że fora motoryzacyjne to siedlisko nieudaczników, którzy często nawet nie prowadzili samochodów, jakie skreślili za 'brzydki wygląd', cierpiących na przekonanie, że na prawdę znają się na motoryzacji, gdy... nie mają o niej pojęcia. Nie marnuj życia, leć robić coś pożytecznego.
Ostatnio edytowany przez Michae, Czw, 16.02.2012, 19:28, edytowano w sumie 1 raz
Czw, 16.02.2012, 19:24 |
fiko7
Samochód: Hyundai i30
Oba są wspaniałe. Piękne, luksusowe i szybkie. Najechętniej wziąłbym oba, ale jak muszę wybierać to Maserati
Czw, 16.02.2012, 19:25 |
zygix
Postów: 929
Samochód: Viggen
PoprawiÄ™ siÄ™
Pią, 17.02.2012, 0:24 |
karol383
Postów: 636 Miejscowość: Suwałki
Samochód: VW Passat B3
GĹ‚os na Maserati,XKR ma juĹĽ swoje lata
Pią, 17.02.2012, 11:36 |
johny
akurat Maserati jest tylko rok młodsze
Pią, 17.02.2012, 11:40 |
Postów: 7496 Miejscowość: Warszawa
biorę Jaguara. BTW szkoda johny że nie przeliczyłeś jednostek
Pon, 20.02.2012, 14:27 |
markus
Postów: 9496 Miejscowość: Warszawa
Samochód: Audi A4 B8 Avant
Szczerze mówiąc obydwa miażdżą i myślę, że w tym porównaniu wybrałbym samochód, który lepiej sprawowałby się w jeździe na codzień. A tak "na sucho" to biorę Maserati, głównie za dopracowany, wyrafinowany i mocno agresywny design.
_________________ http://www.exoticcars.pl
Pią, 24.02.2012, 21:27 |
lordzofmafia
Postów: 6258 Miejscowość: Racibórz - Wawa
Samochód: Das Auto mit TDI
Oba
_________________ Old Opels never die!!! Opel - Wir lieben autos Od dużej pojemności lepsza jest tylko jeszcze większa pojemność - A. Opel 08.2007 - 08.2010 - '93 Opel Vectra GT - Rost In Peace ;(
Śro, 21.03.2012, 16:01 |
BmwM5
Postów: 3894
Ostatnie modele Maserati jakoś średnio przypadają mi do gustu. Jag.
Pon, 26.03.2012, 12:03 |
[ 18 posty(ów) ] |
Użytkownicy przeglądający to forum: Brak zarejestrowanych użytkowników oraz 15 gości |
