Obecny czas: Pią, 19.04.2024, 0:43
Napisz nowy temat Odpowiedz  [ 18 posty(ów) ]
R8 GT vs LP570-4 Superleggera vs 911 turbo S
Mój wybór to:
Audi R8 GT 20%  20%  [ 9 ]
Lamborghini Gallardo LP570-4 Superleggera 57%  57%  [ 25 ]
Porsche 911 Turbo S Coupe 23%  23%  [ 10 ]
Razem głosów : 44
Post R8 GT vs LP570-4 Superleggera vs 911 turbo S
Audi R8 GT
Engine
Configuration 90Âş V 10
Location Mid, longitudinally mounted
Weight 258 kilo / 568.8 lbs
Construction aluminium block and head
Displacement 5.204 liter / 317.6 cu in
Bore / Stroke 84.5 mm (3.3 in) / 92.8 mm (3.7 in)
Compression 12.5:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Direct Fuel Injection
Aspiration Naturally Aspirated
Drivetrain
Chassis/body carbon fibre and aluminium body panels on aluminium spaceframe
Suspension (fr/r) double wishbones, coil springs over hydraulic dampers, anti-roll bar
Steering rack-and-pinion, power assisted
Brakes ventilated ceramic discs, all-round, ABS
Gearbox 6 speed Manual
Drive Quattro All wheel drive
Dimensions
Weight 1525 kilo / 3362 lbs
Length / Width / Height 4435 mm (174.6 in) / 1930 mm (76 in) / 1240 mm (48.8 in)
Wheelbase / Track (fr/r) 2650 mm (104.3 in) / 1638 mm (64.5 in) / 1595 mm (62.8 in)
Performance figures
Power 560 bhp / 418 KW
Torque 540 Nm / 398 ft lbs @ 6500 rpm
BHP/Liter 108 bhp / liter
Power to weight 0.37 bhp / kg
Top Speed 320 km/h / 199 mph
0-60 mph 3.5 s
Engine
Construction aluminium alloy block and head
Compression 12.5:1
Drivetrain
Drive All wheel drive
Dimensions
Weight 1340 kilo / 2954.2 lbs
Length / Width / Height 4390 mm (172.8 in) / 1900 mm (74.8 in) / 1170 mm (46.1 in)
Performance figures
Power 570 bhp / 425 KW @ 8000 rpm
BHP/Liter 110 bhp / liter
Power to weight 0.43 bhp / kg
Top Speed 325 km/h / 202 mph
0-60 mph 3.3 s
Porsche 911 Turbo S
Engine
Configuration B 6
Location Rear, longitudinally mounted
Displacement 3.8 liter / 231.9 cu in
Aspiration Twin Turbos
Drivetrain
Chassis/body unitary steel
Front suspension McPherson struts, lower control arms, coil springs, gas pressurized twin-tube shock absorbers, anti-roll bar
Rear suspension multi-link, coil springs, single sleeve gas pressurized shock absorbers
Brakes ventilated carbon ceramic discs, all-round, ABS
Gearbox PDK Twin Clutch 7 speed Automatic
Performance figures
Power 530 bhp / 395 KW
Torque 700 Nm / 516 ft lbs
BHP/Liter 139 bhp / liter
Top Speed 315 km/h / 196 mph
0-60 mph 3.2 s
Szybsze wersje szybkich supercarĂłw
źródło: insideline
Nie, 06.02.2011, 15:28
Postów: 921
Samochód: DS3 '14
Post Re: R8 GT vs LP570-4 Superleggera vs 911 turbo S
BiorÄ™ Merca SLS AMG :twisted: :twisted: :twisted:
Nie, 06.02.2011, 15:50
Głos na Porsche ;) Klasyczny napęd, świetny boxer umieszczony z tyłu. I ta sama, piękna linia nadwozia od wielu lat.
Nie, 06.02.2011, 16:26
czyli :?:
Nie, 06.02.2011, 16:40
Czyli zapomniał, że Turbo S ma napęd na cztery kółka ;)
Nie, 06.02.2011, 16:41
Postów: 2641
Uscislajac naped klasyczny to taki gdzie silnik jest z przodu a napedzane sa koła tylne wiec zadne 911 nie ma klasycznego napedu.
W tym prownaniu r8 gt prezentuje sie wysmienicie.
Nie, 06.02.2011, 17:23
3. 911 - nuuuuda, idzie usnąć....
2. R8 GT - czyli jak ulepszyć R8 nie pokonując brata, czyli Gallardo :mryellow: świetne auto, jednak natłok zwykłych wersji czyni je nieco opatrzonym...
1. G - cud, miĂłd i orzeszki. Kocham. Uwielbiam. Czyste porno.
Nie, 06.02.2011, 17:37
Fakt, nie wiedziałem że 911 ma tutaj 4x4 :oops: ale i tak większość rzeczy przemawia za nim ;)
Nie, 06.02.2011, 18:08
Ciężki wybór, ale głos na włoskiego byka :wink: Cudownie prezentuje się ta odchudzona wersja Gallardo. Dalej Porsche - klasyka, brak słabych stron, ale tylko miejsce drugie. Trzecie Audi, nie ma się do czego przyczepić i ma kapitalny lakier.
Nie, 06.02.2011, 18:19
Postów: 636
Miejscowość: Konstancin [WPI]
Samochód: V8 M60B40
Lambo > AĹ‚di > Kafer Sport.
Lambo za wyglÄ…d i osiÄ…gi.
HABEMUS SEDAN
Nie, 06.02.2011, 18:40
Postów: 21
Gallardo- Najpiekniejszy, szybszy i wloski.
pozniej 911, cos ma w sobie.
R8- hmm kierownica galardo i r8 bardziej jednak pasuje do lambo.
Pon, 07.02.2011, 0:18
Postów: 1624
Zdecydowanie Porsche. Na pewno najwygodniejsze w uĹĽytkowaniu, a mimo to zapewniajÄ…ce piorunujÄ…ce osiÄ…gi - moje ulubione 911. Sami zobaczcie, jak to przyspiesza :wink:: http://www.youtube.com/watch?v=yqqk5V0uiYc
www.diecastclub.pl
Wto, 08.02.2011, 14:18
pozostałe dwa nie przyspieszają gorzej..
Wto, 08.02.2011, 16:54
Turbo S to faktycznie mistrz przyspieszenia niektĂłre testy dajÄ… wynik 2.9 s do setki, bardzo szybko
Wto, 08.02.2011, 17:36
Postów: 7459
1. Gallardo
2. 911
3. R8 GT
Wto, 08.02.2011, 19:50
Turbo S to maniak przyspieszeń, robi to lepeij niż najmocniejsze GT2 RS, poza tym koła montowane na jedną centralną śrubę to mega fajny bajer
2 Audi
3 Lambo
Pią, 11.02.2011, 16:41
Postów: 1889
Dlugo sie zastanawialem nad wyborem i dzis wiem, ze chcialbym Audi, nie jest najszybsze, najbardziej spektakularne, jednak podoba mi sie to co oferuje.
Deszcze Niespokojne.
Mecze na żywo
Pią, 11.02.2011, 17:22
Zdecydowanie Lambo. Podoba mi sie najbardziej z całej 3.
Potem Audi. Bo je lubie i mi sie podoba ;)
Daleko daleko z tyłu Porsche. Jedyną 911 jaka mi podchodzi jest 911 GT3 RS :twisted:
Nie, 13.02.2011, 18:10
