Samochody Świata - Forum Motoryzacyjne
https://www.samochodyswiata.pl/
Pojazdy pancerne --Cougar--
https://www.samochodyswiata.pl/viewtopic.php?f=23&t=17275
Autor:  ixxos [ Sob, 09.12.2006, 12:36 ]
Temat postu:  Pojazdy pancerne --Cougar--
4 X 4
ENGINE Caterpillar C-7 Diesel (mil spec)
HORSEPOWER 330 @ 2400 rpm
TORQUE 860 Ft lbs @ 1450 rpm
SPEED Tires rated at 55mph (operational sprint 65mph +)
RANGE Up to 600 miles on-highway
TRANSMISSION Allison HD Automatic
FRONT AXLE Marmon-Herrington MTL-92H
REAR AXLE Marmon-Herrington RF-92H
TIRES Michelin XZL 395/65 R20
SPARE TIRES One standard
RUN FLATS Hutchinson VFI
ELECTRICAL Voltage 24v
BRAKES Air
LENGTH OVERALL 233”
WEIGHT Curb 30,000 lbs
WEIGHT Max (GVW) 35,000 lbs
PAYLOAD (Max) Up to 4,000 lbs
LENGTH HULL-INTERNAL Approx 108” behind front seats
6 X 6
AIRCON Dual units rated at 24,000 & 48,000 BTU
SEATING Driver & co-driver plus up to 8 passengers
SEAT BELTS Four-point harnesses, all occupants
ARMOR 7.62 x 51mm NATO Ball standard
GLASS 7.62 x 51mm NATO Ball multi-hit standard
MINE PROTECTION All wheels and centerline protected
HATCHES 3 topside
DOORS 3: Driver, co-driver and rear crew double door
HEIGHT Approx 104” including hatches/ad 26” for gun shield
WIDTH 100” without mounted spare tires/108” with mounted spare tires
LENGTH OVERALL 279”
WEIGHT Curb* 37,000 lbs
WEIGHT Max (GVW)* 51,000 lbs
PAYLOAD (Max)* 12,000 lbs
(C)http://www.defenseindustrydaily.com/
Pojazdy te uĹĽywane sÄ… w Iraku
jeszcze kilka fotek
(C)http://www.forceprotection.net/models/cougar/ -adres producenta sÄ… tu teĹĽ filmiki
Autor:  rumun19 [ Sob, 09.12.2006, 12:42 ]
Temat postu:
Fajny pancernik:)Cieakwe ile tako pojazd moze wychalc ropy??
Autor:  Mibay [ Sob, 09.12.2006, 16:59 ]
Temat postu:
Pewnie z 50/100 :D albo i więcej.
Autor:  pardon [ Sob, 09.12.2006, 20:23 ]
Temat postu:
ixxos napisał(a):
51,000
co? prawie 25 ton :shock: ? jeśli to ciągnie 330-konny motor to nieźle musi żłopać paliwka... spalanie pewnie przelicza się nie na 100km lecz chyba na motogodziny :shock:
wspaniałe pancerniaki w pustynnym layoucie :shock: :shock:
Autor:  witek11 [ Sob, 09.12.2006, 22:15 ]
Temat postu:
ło ale sprzet! jaki masywny przod! zastanawia mnie umiejscowienie systemu odprowadzania spalin... ciekawe ile daliby za niego na zlomie 8) to kawal ciezkiej blachy... niesamowite
Autor:  Konradek [ Sob, 09.12.2006, 22:57 ]
Temat postu:
Wygląda świetnie, ciekawe co to auto jest w stanie przetrwac :)
Autor:  RR ltd Co. [ Sob, 09.12.2006, 23:47 ]
Temat postu:
Ale ekstra! Dwuosiówka rządzi!!! Wygląda jak rozwścieczony nosorożec w sawannie :lol: Niestety dane techniczne nic mi nie mówią e.g. TORQUE 860 Ft lbs @ 1450 rpm...
Autor:  Mucios [ Nie, 24.12.2006, 23:13 ]
Temat postu:
ciekawy poijazd pancerny
Autor:  Freeze [ Nie, 24.12.2006, 23:18 ]
Temat postu:
Konradek napisał(a):
co to auto
to że ma koła to nie znaczy że to auto :lol:
Strona 1 z 1 Wszystkie czasy w strefie UTC + 1 godzina
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
http://www.phpbb.com/
