| MOWAG Eagle https://www.samochodyswiata.pl/viewtopic.php?f=23&t=16810 |
Strona 1 z 1 |
| Autor: | RR ltd Co. [ Wto, 21.11.2006, 23:08 ] |
| Temat postu: | MOWAG Eagle |
Mowag Eagle I
Mowag Eagle II
Mowag Eagle III
Mowag Eagle IV
Cytuj: TECHNICAL SPECIFICATIONS Weights Ready for operation: 5600 kg Payload Baseline: 2900 kg Payload at Level 3: 2300 kg Gross vehicle weight: 8500 kg Dimensions Overall length: 5.36 m Height: 2.30 m Overall width: 2.16 m Wheelbase: 3.53 m Ground clearance: 0.40 m Angle of approach: 42° Angel of departure: 45° Number of seats: 4 (5) Vehicle Performances Max. speed high range: 110 km/h low range: 60 km/h Gradient: 60% Vertical obstacle: 0.40 m Turning circle diameter: 16.5 m Fuel tank capacity: 180 litres Range on roads: 700 km Power-to-weight ratio: 29.4 HP/t Engine ^ Top Manufacturer: Cummins Type: ISBe 5.9L Turbo Common Rail Function: 4-stroke / Diesel No. of cylinders: 6 Performance: 184 kW (250 hp) Emission limit: EURO III Torque: 750 Nm Transmission Manufacturer: Allison Type: 2500 SP Transmission: 5-speed automatic Driveline and Suspension ^ Top Wheel drive: Permanent, four wheel Transfer case: Two-speed Differential: Torsen, self locking DeDion axles with wheel hub gear, patented roll stabilizers Brakes: Air over hydraulic disc type with ABS Steering: Hydraulic power assisted Tires: 335 / 80 R 20 Baseline Equipment * Air conditioning system * Vehicle information system * Runflat tires Baseline Protection Ballistic: 7,62 x 51 Mine: 6 kg TNT under any wheel Optional Equipment ^ Top * Winch * Central tire inflation system (CTIS) * Preheat unit * NBC overpressure system * GPS * Add-on kit for increased mine protection * Add-on ballistic protection kit for STANAG 4569 Level 2 and 3 * Seats for enhanced protection * Provisions for various weapon stations * Provisions for various radio systems * Provisions for various BMS systems * Mission related cargo module * 5 seat version with raised roof * Snow chains * EURO IV engine * Trailer hitch (c) mowag.ch, mmvsgogr.ch, armyvehicles.dk, defense-update.com, haborumuveszete.hu, henrikc.dk, vim.ch, defenseindustrydaily.com, segurancaedefesa.com, forsvaret.dk, interarmees.fr, |
| Autor: | ixxos [ Śro, 22.11.2006, 9:12 ] |
| Temat postu: | |
taki Hummer |
| Autor: | pardon [ Śro, 22.11.2006, 11:04 ] |
| Temat postu: | |
ale kloc |
| Autor: | ixxos [ Śro, 22.11.2006, 13:38 ] |
| Temat postu: | |
Performance: 184 kW (250 hp) hp: - konie mechaniczne 110km/h to niby mało |
| Autor: | spirit [ Śro, 22.11.2006, 15:50 ] |
| Temat postu: | |
lol ale wypasione |
| Autor: | gw89 [ Pon, 11.12.2006, 4:04 ] |
| Temat postu: | |
z tymi antenami wyglada jak autko sterowane |
| Autor: | witek11 [ Pon, 11.12.2006, 18:28 ] |
| Temat postu: | |
powarzne wojskowe auto... niebezpieczny konkurent hummera... piekny,masyw nadaje mu wizualnej sily |
| Autor: | budzyfer [ Pon, 11.12.2006, 18:35 ] |
| Temat postu: | |
RR ltd Co. napisał(a): Fuel tank capacity: 180 litres Range on roads: 700 km Czyli nie jest tak tragicznie ze spalaniem:) |
| Autor: | olokolo [ Pon, 11.12.2006, 21:40 ] |
| Temat postu: | |
witek11 napisał(a): powarzne wojskowe auto... niebezpieczny konkurent hummera... piekny,masyw nadaje mu wizualnej sily Konkurent nie - Eagle powstaje na bazie Hummera ... |
| Autor: | RR ltd Co. [ Pon, 11.12.2006, 22:51 ] |
| Temat postu: | |
Eeeeeeee... Naprawdę - skąd te wieści? |
| Autor: | Seth [ Wto, 12.12.2006, 0:17 ] |
| Temat postu: | |
olokolo napisał(a): Konkurent nie - Eagle powstaje na bazie Hummera ... nie wierzÄ™, szwajcarzy raczej nie robili by nic takiego |
| Autor: | ixxos [ Wto, 12.12.2006, 8:04 ] |
| Temat postu: | |
Hummer jest mniejszy, lżejszy i to widać gołym okiem więc nawet jeśli, to jakie elementy miały by od niego pochodzić - bez sensu takie rozumowanie |
| Autor: | olokolo [ Wto, 12.12.2006, 8:18 ] |
| Temat postu: | |
ixxos napisał(a): Hummer jest mniejszy, lĹĽejszy i to widać goĹ‚ym okiem wiÄ™c nawet jeĹ›li, to jakie elementy miaĹ‚y by od niego pochodzić - bez sensu takie rozumowanie "Eagle I, II i III bazowaĹ‚y na Humvee.Najnowszy - IV - bazuje na MOWAG Duro.MOWAG naleĹĽy do General Motors Defense of Canada (część General Dynamics) i wchodzi w skĹ‚ad General Dynamics European Land Combat Systems, wraz z Steyr-Daimler-Puch z Austrii i z General Dynamics, Santa Barbara Sistemas (GDSBS) z Hiszpanii "- cytat z innego forum. |
